Pages: 1 ... 6 7 [8] 9 10 ... 12
Author Topic: Almost  (Read 103505 times)
Re: Almost
« Reply #105 on: November 15, 2017, 03:30:36 AM »
Well guys, it seems my experimental T stat placement is working, I did pick up another to try.
Re: Almost
« Reply #106 on: November 15, 2017, 05:10:38 AM »
Good news! I just can't wrap my head around where the other half of a firebox full of wood went in the building.
Re: Almost
« Reply #107 on: November 15, 2017, 05:21:05 PM »
You could definitely tell it was warmer than 66 in there, fog up your contacts on a few mornings.
Re: Almost
« Reply #108 on: November 16, 2017, 06:34:42 AM »
So basically your saying the old thermostat was reading colder than it actually was and ran the heat more than needed?
Re: Almost
« Reply #109 on: November 16, 2017, 07:35:07 AM »
Well hmm, I guess I thought you would have mentioned that it was awful hot In the garage.
Re: Almost
« Reply #110 on: November 16, 2017, 03:43:38 PM »
I never really checked with another thermometer, always went by the thermostat, but a few readings of the floor ( 74)with the thermostat up 4 ft wouldn't really notice the difference unless barefoot. But 8 degrees is a lot.
Re: Almost
« Reply #111 on: November 16, 2017, 04:25:56 PM »
So it has actually been 75 degrees in the building??? How could you do any work in there? I sweat working at 60 degrees.
Re: Almost
« Reply #112 on: November 16, 2017, 04:37:36 PM »
Not me, I hate working inside anyways, if I’m gonna spend the whole day in the shop I work in a short sleeve t shirt and sneakers, therefore its set at 70.
Re: Almost
« Reply #113 on: November 16, 2017, 04:54:45 PM »
No the floor was at 74, thermostat said 66, actual temp I do not know, but will get a regular thermometer to test.
No way in hell would I work in that heat either.
Re: Almost
« Reply #114 on: November 16, 2017, 05:26:44 PM »
Yeah, so if the room is at a workable temp than I don’t see where the btus are. Can you place a thermometer at the peak of the building?
Re: Almost
« Reply #115 on: November 16, 2017, 06:26:13 PM »
I hooked up a regular mechanical, turn the dial yesterday, I put the digital right next to it when I got home tonight, just checked it.  Mechanical set at 68, not calling for heat.  Digital was at 64
Re: Almost
« Reply #116 on: November 16, 2017, 08:04:28 PM »
So atleast 4 degrees off at the floor. I wonder what temp the peak is at.
Re: Almost
« Reply #117 on: November 17, 2017, 04:53:20 AM »
Hoping the t stat thing works, I got 6 days out of half a cord.
Re: Almost
« Reply #118 on: November 17, 2017, 05:55:40 AM »
I wonder as well, without the ceiling fan running in the shop it can easily be 20 degrees warmer at the peak, but I’m using forced air for heat.
wreckit87
Re: Almost
« Reply #119 on: November 17, 2017, 06:50:10 AM »
I have 3 thermometers around the shop with one at the lid and the other 2 in opposite corners with the wall stat 4ft high in another corner. Both wall thermometers are always within 2 degrees of what the wall stat is (cheap 120V Honeywell) and the one at the lid usually runs about 4 degrees over, no ceiling fans. I really can't tell the difference on the woodpile if the shop floor is calling or not, burn seems to be the same day to day. Now if I turn on the unit heater, different story. That'd get rid of half a cord in a week too probably if I ran it all the time and kept it at 66. I leave the shop at 55 via the floor, and it's sweaty in a T-shirt when working. Unit heater is for when I wanna melt something off quick or sit around and drink beer, but even then 65 will cook me right outta there
